13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
609 Questions View all
Battery Is Not Charging
I just bought faulty mac from ebay, and trying to restore it.
I just tried to launch it without battery, and it was ok. after I bought new battery, and installed it, Its working fine, but have problem with charging.
Actually problem is: no any lighting(orange or green) on Magsafe connector and OS indicating "Battery Is Not Charging" but charger charging battery very slowly.
I already tried to reset SMC and PRAM with no success.
May be there is some solutions at this case?
Probably I bought faulty charger or MagSafe logic circuit?
There is some info about Power in my system:
Battery Information:
Model Information:
Serial Number: W011858G7D3LA
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 201
Hardware Revision: 000a
Cell Revision: 165
Charge Information:
Charge Remaining (mAh): 1685
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 5812
Health Information:
Cycle Count: 2
Condition: Normal
Battery Installed: Yes
Amperage (mA): 103
Voltage (mV): 11334
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
PrioritizeNetworkReachabilityOverSleep: 0
Battery Power:
Display Sleep Timer (Minutes): 2
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Revision: 0x0000
Family: 0x0000
Serial Number: 0x00000000
Charging: No
Comments:
Have you tried a second charger yet?
by
yes, today I been in Apple Store and tried to connect L-shape charger, and it had green light on connector, but had same problem "Battery Is Not Charging
system power information was shown same description. in my opinion its looks like system dont recognising charger.. Which component or circuit is responsible for it? it can be Magsafe DC-IN BOARD Power?
cheers!
by
Add a comment
Free shipping on orders over $20
Use code BLUEANDBLACK at checkout
1 Answer
Chosen Solution
At this point you'll need to open the system up to see whats up.
The DC-in board is mostly passive in this model (very little circuitry). The underside of main logic board near it has most of the battery control logic.
Look for liquid damage or a burn't component on both boards.
Make sure you follow proper ESD practices. Good Luck!
Score 1
Add a comment
Add your answer
Alexander Letetsky will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 23
All Time: 3,350
