Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Trying to install Leopard, but MacBook stalls
Hi everyone,
Let me give a quick rundown of the situation. I am repairing a MacBook for a client who complained a few weeks ago about the laptop not starting up correctly. From the information I have gathered, this seemed to have occurred without any preliminary symptoms.
First thing I did is enter disk utility using her leopard install disk and ran all the diagnostics possible on the drive and everything seemed to be okay. I tried to erase the drive and create a new partition without success. I received a resource busy error. So, I grabbed a windows xp disc and wiped the drive using that, and went back to disk utility and created a new journaled partition. After all this run around, I began the install and everything was going nicely until 3/4 through I received an install error.
I went back and ran more diagnostics on the drive, and again no problems found. I wiped the drive again, partitioned, and tried once more, but the install stalled saying 27 minutes left for completion and sat there for at least two hours. At this point I halted the install and made a diagnostic inference: the hard drive must be bad.
So, this is where I am at a crossroad. I just would like reassurance that I have come to the most logical conclusion, and if I haven't I would greatly appreciate any advice.
Thank you in advance.
Score 1
Add a comment
Chosen Solution
I would have to say that the hard drive is bad, If it stops responding after extensive use, then it may be time for a replacement.
1 Comment:
Yeah I came to conclude this after several install attempts, zeroing out the drive and reformatting a few times. Thanks for the input.
by
Add a comment
Most Helpful Answer
I've run into this this same problem. The next thing I did was to repartition and zero the hard drive. Here's the link to my attempt: Unable to Format 30 GIG Quantum Fireball Plus hard drive?
Score 1
3 Comments:
Hmm, okay. I read the thread you linked me to, and I'll give it a shot. So you're saying I should zero out the drive AFTER it's unmounted? Then from there re-partition?
by
I'm saying that's what I did on my own machine. My hard drive eventually turned out to have so many bad blocks I had to trash it. Yours may not be as bad.
by
it has to be mounted to reformat and zero out the data. go to format options and select "write zero's"
by
Add a comment
Add your answer
linktothepast21 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,109
