Repair information and guides for MacBook Pro models with 13" displays.
9739 Questions View all
won't turn on and does a beeping soung instead
Hi there, I had some problem with my macbook pro a while back, in which the screen was getting blank/frozen and I had to force quit it, and when i tried to turn it back on, it started beeping and would not turn on...then I would wait some hours and it would finally turn on. It was acting like this for a while and I managed to fix it by repairing the disk in disk utility and it was working fine...
Now, since yesterday, it started again, and i had to force quit it, but this time, it is not turning on at all anymore, and it only does the beeping sound when I try to turn it on...firts it does one beeping at a time, and then I force quit it again and turn it on again and it does a faster beeping sequence.
Can anyone help me?
my mac info is:
Mac OS X
version 10.6.8
2.4 GHz Intel Core 2 Duo
4 GB 1067 Mhz DDR3
I never did any work on it, never changed anything...it is just like I got it from the shop.
Thanks
Score 5
1 Comment
Can you supply the last four digits of your serial number so we can ID your system.
by
Add a comment
Chosen Solution
3 successive tones, a 5-second pause, 3 successive tones is the RAM integrity error. As Bernd recommended reseat your memory or replace it.
Heres the Apple TN on boot up tones Tone Errors for reference
Score 2
Add a comment
Hi Tania,
how many beeps do you hear? Or is it beeping constantly without an interruption? Sometimes this symptom is caused by the memory. Have a look if it is seated propperly.
Good luck
1 Comment:
The power on self test error codes either beep or blink the sleep lite in repeating patterns. Click here to go to a thread that explains what the different ones mean.
by
Add a comment
Start up and hold down the on/off button until led will blink rapidly and mac will start up fine.
2 Comments:
i am getting repeated 2 beeps and mac wont start up. I have not changed hard disk or anything in my Mac book pro.
Please help
by
Ali - For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the appropriate Answer, Question or create your own original Question. FWIW 2 beeps mean in "old code" it meant incompatible RAM in "new code" it's no longer listed.
by
Add a comment
What the !&&* is this 100 points or can't vote no. The suggestion did NOT work.
1 Comment:
Larry please explain what didn't work.
by
Add a comment
Add your answer
Tania will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 66,924
