Will replacement trackpad solve my problem?
I own a MacBook A1342. Like many others before me I have problems with the trackpad.
The problem is that I cannot use the mechanical click function. I've tried fiddling with the trackpad screw under the battery but with no luck. Also, I've played around with settings, reset the PRAM etc.
I used to be perfectly happy with my MacBook so I am about to go out and buy a new trackpad to replace the old one. As they are expensive I want to make sure that this is a solution to my problem. Might there be other malfunctioning hard- or software issues I haven't checked? Can it be the logic board?
Thank you for your time!
I have the same problem , but neither tap-to-click or mechanical click are working... Anybody has being throug the same problem??
Thanks in advance
by sergi marcet
