The Samsung Galaxy S 4G is an Android 2.2-powered smartphone with a 4-inch AMOLED touchscreen display and 1 GHz processor.
82 Questions View all
Why is my phone not charging?
when I connect the charger to my phone it does not charge, but if I bend it back and forward, it is really rare it will charge.
Add a comment
Chosen Solution
Angela Molina, if the "bend it back and forward" shows some results, it does sound like a bad charging port. Start off by using a new cable and see if that makes a difference. It is possible that the plug on the cable end is worn out. If it does not, you may have to replace the charging port. Take a look at the teardown and see if that is something you are comfortable with. You will have to solder a new connector to the board. The port is available at places like this. Hope this helps, good luck
Score 1
Add a comment
how to on home page info via setting
Add a comment
Add your answer
Angela Molina will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 11,098
