iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
903 Questions View all
Replacement LCD screen is white after installing
Hi all, I'm working on an 80 gig iPod Classic for a friend of mine. The original LCD screen's backlight gave out, so we decided to replace it. I followed the directions to replace the LCD carefully, and now it just gives me a white-ish grey screen. I've tried a hard reset several times, and a manual restore through iTunes (it sees the iPod perfectly).
I figured that maybe the connections weren't seated properly, so I reseated them very carefully, and still had the same problem. I even removed the connection to the new screen and connected the old screen with the out-of-order backlight, and the screen functioned properly (without the backlight, of course). It plays music just fine, too. Does anyone have any ideas, or maybe I got a defective replacement part? Thanks!
Add a comment
1 Answer
Most Helpful Answer
Jordan Wagner, since your old screen works, it is very unlikely that it is your iPod that is failing. Sounds to me like you got a bad Display. I would return it to the vendor. Make sure you have an iPod Classic and not an iPod Video LCD.
Score 3
1 Comment:
Thank you for replying! I'll contact the vendor right away.
by
Add a comment
Add your answer
Jordan Wagner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 932
