This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
87 Questions View all
Jump past the front side window button to get window up?
Window will not go up on passenger side window. I would like to know how to take the side panel off and jumper past it. What contacts do I use? All the other windows work fine. It is just the button on the door panel. The button will take the window down, but not up.
Comments:
Just bridge the contact on the switch and see if it moves the window up
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
williamsk, this video should get you started., Still checking on the diagram about which contacts to use. You should get away with trying the ones on your switch first. Also, check all your fuses and make sure your lock switch is in the unlock position:-)
Score 1
Add a comment
Add your answer
williamsk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 585
