Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Dropped my iPhone face down & there is now a spider crack?
I dropped my iPhone face down on concrete & now there is a huge spider web crack across LCD. Touchscreen parts all still work, however I was wondering what to buy to replace the screen?
Thank You!
UPDATE : iPhone 3G....8gb
I think it may just be the glass, because everything still works just fine.. its just covered in cracks..
Score 1
2 Comments
Could you let us know which iPhone model you have? 1G , 2G, 3G, or 3Gs
by
What gen do you have? Also, are you sure the display is cracked? And not just the glass?
by
Add a comment
Chosen Solution
Since you said you have a 3G Here is the link to the parts:
http://www.ifixit.com/iPhone-Parts/iPhon...
and select your parts and order.
To replace it go to:
iPhone 3G Display Replacement
those are the instructions if it is a 3rd Generation. Give it a try. It really isn't too hard. Good luck
Score 2
4 Comments:
The poster has not specified which gen she has.
by
Hence the question before yours on the top asking for the info. So this way she gets a head start in seeing what is out there until she can let us all know which one she has. And if it is already covered she is good to go. It is her we are trying to help. RIGHT???
by
Follow the link to order the part, looks like around $54. Then go to the other link for the 3G teardown and replace the touch screen. If you need the suction cups to remove the screen look in the tools section in the parts area. Give it a try.
by
This is the wrong part mactech, the display is not cracked, just the glass, read the post.
by
Add a comment
So what you need to replace is just the front panel assembly, which includes the glass.
Score 1
2 Comments:
Even though this part that RAB777HP suggests may be twice as much as one mentioned above and include stuff you do not need, It is much easier to replace all together than the one I mention above especially if you are new at pulling things apart. Good option. +1
by
actually no, the part you suggested is the display, which has nothing to do with what the poster needs to replace.
by
Add a comment
you need the LCD Touch Screen.
Add a comment
I have a 4glte samsung admire 2
1 Comment:
@john, not quite sure what you are asking, commenting, or answering. If you need some help, use this link http://www.ifixit.com/Answers/Ask/iPhone... to ask. Just give a lot more information then you have on here.
by
Add a comment
Add your answer
Sarah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 5,888
