Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
"Searching" after disconnectet battery?
Hello guys.
I have noticed something, and was wondering if this is a bug anyone else is seeing.
After disconnecting the battery on the iPhone 4s, the information bar is saying "searching" all the time, even when the SIM card is not in the phone.
I have worked on many devices and never seen this problem until IOS6 showed up!
After a restore the phone will go from searching to recognizing the SIM, so this seems to fix the problem.
However, is there a way to solve this error without having to restore? Like a software fix?
Thank you.
Jon
Score 1
1 Comment
im having the same problem i tryed everything
by
Add a comment
Chosen Solution
Set the date/time manually to the correct values and then restart the phone. Worked for me :)
Score 7
1 Comment:
THANK YOU! This solution works like a charm. I have use it 3 times now. No problem at all. Thank you Marcus.
Jon
by
Add a comment
Well, found a solution to this problem. After changing three screens on iPhone 4S with iOS6. All three with this problem. The solution I found: Insert the sim before you turn on the phone. Then connect the iPhone to the WiFi. Take the sim card out, and put if back in ;) Hopefully this will resolve the problem.
Score 2
2 Comments:
Hi Alex, your solution work fine, thanks for all.
by
Danke ;)
by
Add a comment
Add your answer
Jon Lund will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,262
