Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2912 Questions View all
What might have cause that?
Hey! recently my iphone is overheating and drains out of battery.
I thought that the battery is broken so I bought a new one and replaced it , at first it was ok but after 2 hours it happened again (overheating and drains out the battery) I really dont know what to do.
by the way when I took out the battery i noticed a little weird black piece connected to the battery connector with the same screw!
can u help me???
Comments:
The little black piece is the antenna wire cap cover. It goes at the top battery screw, under the battery snap down connector. It is not causing the problem the iPhone is having.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
What you have done is pulled out the battery connector when you removed the battery. Many people do this.
What you need to do is find a company that can resolder the battery connector back to the motherboard. We do this repair all of the time. Hopefully you have not lifted any of the solder pads from the motherboard.
Rick
Florida iDoctor
Comments:
Hey Rick, from what you saying that the reason for causing my problem?
by
Add a comment
Add your answer
shahar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 388
