Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
571 Questions View all
Can I replace dead superdrive with a SSD hardrive?
I have a Model A1224 / Mid 2007 / 2 GHz Core 2 Duo processor / 4 Gigs Ram ver 10.6.8
Can I replace my dead optical superdrive with an SSD drive?
What kind of enclosure do I need and can I use the
existing cables in my iMAC to achieve this?
Add a comment
1 Answer
Chosen Solution
Here is the guide to replace the optical drive with a hdd or ssd.
Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive
Your iMac will need a ATAPI enclosure like this one:
http://www.pro-battery.com/battery-detai...
If you take that info and look for the equivalent on iFixit this is what you will find:
12.7 mm PATA Optical Bay SATA Hard Drive Enclosure
12.7 mm PATA Optical Bay SATA Hard Drive Enclosure Image
Product
$19.99
Score 2
Comments:
Thank you Jay for your info
Can you tell me what kind of enclosure/caddy I need and can I use the
by
I do appreciate the time you took to answer my question.
But your link says it's for a mac Mini not a Mid 2007 / 2 GHz Core 2 Duo processor desktop. I'm still stuck with no answer.
by
I just edited my answer and added links to the proper enclosure. I did a quick search on your iMac and found that the one in the guide will not work as its SATA and not ATAPI.
by
Add a comment
Add your answer
Sam will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 9,062
