13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Question Closed
Do I need an "enclosure" to clone my hard drive?
I'm a first time DIYer at this. I'm cloning my hard drive to a larger hard drive so I can replace the internal HD. I have a USB 2.0 to SATA?IDE Adapter Cable. Do I have to have an "enclosure" for the new HD in order to move my data from the existing internal HD to the new external HD which is a &%) GB 7200 RPM Seagate SATA HD?
Add a comment
Chosen Solution
No, but ... If you did you could use the HD as a backup or a means to extend your MacBooks storage externally. What plans do you have for the old drive assuming it still healthy & works? Collecting dust.
If you do get an external case I'd go with a Firewire or dual FW & USB case.
Score 1
1 Comment:
Yes, this is also quite a good option.
by
Add a comment
Most Helpful Answer
No, the USB to SATA will do. Once you swap them, you can use the migration assistant to copy your old HDD.
Score 3
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,879
