video and webcam drivers
What type of video card or controller drivers
this type of iMac have...also the isight webcam type and drivers
Mac OS X 10.6 "Snow Leopard" compatibility
Grand Central Dispatch is supported.
64-bit operation is supported.
OpenCL is not supported.
CPU: 2.0/2.4 GHz Intel Core 2 Duo 'Merom', 2.8 GHz Core 2 Extreme option
bus: 800 MHz
performance:
Geekbench 2 (Leopard): 3614 (2.8 GHz), 3127 (2.4 GHz), 2642 (2.0 GHz)
Geekbench 2 (Tiger): 3740 (2.8 GHz), 3213 (2.4 GHz), 2741 (2.0 GHz)
RAM: 1 GB, expandable to 4 GB using two PC2-5300 DDR2 SODIMMs
Graphics, 2.0 GHz: ATI Radeon HD 2400 XT with 128 MB RAM (256 MB optional), supports up to 1920 x 1200 external digital display, 2048 x 1536 analog display, and monitor spanning
Graphics, 2.4 GHz: ATI Radeon HD 2600 Pro with 256 MB RAM, supports up to 1920 x 1200 external digital display, 2048 x 1536 analog display, and monitor spanning
monitor:
20" 1680 x 1050 flat panel display (18-bit LCD)
24" 1920 x 1200 flat panel display
video out: mini-DVI, VGA, S-video, composite (requires adapter)
L2 cache: 4 MB shared cache on CPU
hard drive: 250/320 GB 7200 rpm Serial ATA drive
SuperDrive: writes DVD±R and DVD+R discs at up to 8x speed, dual layer at up to 4x; DVD-RW at up to 6x; reads DVDs at up to 8x, writes CD-R discs at up to 24x, writes CD-RW discs at up to 16x, reads CDs at up to 24x
USB: 3 USB 2.0 ports, only 1 high-powered device device allowed
FireWire 400: 1 port, 7 Watts
FireWire 800: 1 port, 7 Watts
Optional 56 kbps USB modem supports v.92 standard
ethernet: 10/100/gigabit
AirPort Extreme: 802.11n
Bluetooth 2.0: included
IR receiver: supports Apple Remote (included)
Microphone: internal
power: 180W
H x W x D (20"): 18.5 x 19.1 x 7.4 in/46.9 x 48.5 x 18.9 cm
H x W x D (24"): 20.5 x 22.4 x 8.1 in/52.0 x 56.9 x 20.7 cm
weight (20"): 20 lb/9.1 kg
weight (24"): 25.4 lb/11.4 kg
Part no.: MA876 (20" 2.0 GHz), MA877 (20" 2.4 GHz), MA878 (24")
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,623
