Can hard drives from a PowerBook G4 and iBook G4 be switched?
Okay here's the deal. I bought a replacement 250gb hard drive for my 12" 867MHz PowerBook G4 about a year ago. Since than the rest of the computer has started to crap out. (Keyboard doesn't work, problems with the screen, and flaky AirPort) Here's my question, is it possible to swap out the hard drive and ram into a 12" 1.33GHz iBook G4? The reason for this is that I do a lot of work in PhotoShop and I need 1gb of ram to run it and it would also be nice to have the larger hard drive (current size 40gb)
Any inside would be helpful.
Score 1
Everything worked great! Thanks for the help guys!
Add a comment
Chosen Solution
Yes, also the Optical drives and memory chips are interchangeable.
I recently took the optical drive as well as the HD out of my 1.33 GHz 12 inch PowerBook (phew, what a tear down that was!!) and placed them in a 1.2 GHz G4 iBook. I put the combo drive and HD back into the PowerBook for S & G's since I had a repair shop tell me the PowerBook's motherboard was damaged after a bellhop dropped it November of '08. What the heck, experience is experience.
I also took the 512 MB chip out of the bottom and placed it in the iBook. There is 256 MB on the board of the PowerBook so it would not miss the chip, besides, it was supposed to be dead.
The iBook works like a champ (also a previous victim of a Apple store Mac-Genius telling my ex it's motherboard was shot). All it needed was a DC-IN board ($49.95 from here) and it came back to life.
Now with 768 MB of RAM, a superdrive all courtesy of the alleged dead PowerBook, runs great. It even runs Leopard but I plan on going back to Tiger once I find the darn disks. Leopard makes all my G4's run slow, even my G4 Dually QuickSilver, which now is connected to my large screen TV courtesy of a special HDMI/ADC cable I picked up at the 2010 CES in January (free to boot!)
Long story short, not only did the iBook roar back to life, the PowerBook also came back to life (praise Gawd, reverend Billy). Now with a 320 GB HD and a 1 GB chip. I love that little machine. Once I can find a superdrive that will do dual sided DVD's (and the money!), I will replace that nasty combo drive and my little PowerBook will be awesome again....
Score 1
Add a comment
Most Helpful Answer
Brett: I checked with and the memory looks to be compatible between the two laptops you mentioned above. On the hard drive they are both 2.5" eIDE's so that should be good. The only issue you need to be ready for is if you the operating system does not like the new computer. If not you may need to reinstall the system, or at the least update it. Good luck
Score 2
Add a comment
Yes, as long as everything is the right size, it'll work in all iBook G4s and Aluminum PowerBooks
Score 1
Add a comment
Add your answer
Brett Morris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,207
