Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac Mini Server configuration.
187 Questions View all
front indicator light does not come on after opening up mini
This if for a mac mini mid 2011 i7. I wanted to find out how hard it would be to replace the hard drive on a mac mini without actually replacing the drive. I used the instructions found on fixit. I stopped short of removing the logic board. I then put everything back together and everything works fine, EXCEPT the front led light no longer lights. So, what is the light connected to? Could this be something as simple as a connector or might I have done damage to something major?
thanks
John Prokopek
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Yes - you could have damaged your device, or missed a connection. First try an SMC reset - then recheck your reassembly.
If this answer was helpful please remember to return and mark it Accepted.
Comments:
thanks, I'll give it a try in the morning. Any idea what the light is connected to? If I decide one day to be a little more ambitious I might break the whole thing down.
by
Add a comment
Add your answer
john will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 609
