Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Why internal mic works only when display lid is fully opened?
Internal mic works only when display is almost fully or fully opened. So could it be mic connector on the logic board or the mic cable? Any experience of this fault? If I looked from the guide section correctly there should be a screw securing mic cable to the computer. So is it more likely that the cable is broken? I hope it is a loose connector because it would be easier to fix..
Score -1
Add a comment
1 Answer
Chosen Solution
I think you've made an accurate diagnosis of the issue. I'd replace the cable, probably Apple part #922-7888. I'd also examine the inverter cables that travel the same hinge while you're at it. I don't know your exact machine but this part will work in the following and can be found for $1.00 with a web search.
Macbook 13.3" 2.0 GHz Intel Core 2 Duo White - Apple Computer MA700LL/A
Macbook 13.3" 2.0 GHz Intel Core 2 Duo Black - Apple Computer MA701LL/A
Macbook 13.3" 1.83 GHz Intel Core 2 Duo White - Apple Computer MA699LL/A
Macbook 13.3" 2.16 GHz Intel Core 2 Duo White - Apple Computer MB062LL/A
Macbook 13.3" 2.16 GHz Intel Core 2 Duo Black - Apple Computer MB063LL/A
Macbook 13.3" 2.0 GHz Intel Core 2 Duo White - Apple Computer MB061LL/A
Score 4
2 Comments:
Thanks! Found for $0.25 from Powebookmedic. :) My machine is late 2006 1.83GHz C2D. There's no guide for microphone replacement so which guide should I follow? iSight guide..?? Hope not, it's looong! Ps. This is a great site!
by
Yes, you will have to follow the iSight guide.
by
Add a comment
Add your answer
Pekka Kurki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 458
