Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
iPhone thinks there is a sim, when there isn't?
Hi, I just repaired my iPhone screen, and I have done a few before with no trouble, but this time once I had put it back together, it is always searching for reception, but never finds it.
I tried restarting, taking the sim out etc but even without a sim, it doesn't say 'no sim' it still says searching.
Can anyone tell me what is going wrong and how to fix it?
Score 2
Add a comment
Chosen Solution
Not totally a apple head here but i do know the iphone 4s has GSM (sim card) and CDMA cellular. i think this plays a role in this.
check your phone settings, And or a restore.
Score 1
Add a comment
Most Helpful Answer
Set the date and time manually to the correct values and then restart your phone. Worked for me :)
Score 2
Add a comment
I've got the same problem.. No one with a helpfull answer for this? Please
Score 1
1 Comment:
Well, found a solution to this problem.
After changing three screens on iPhone 4S with iOS6. All three with this problem.
The solution I found: Insert the sim before you turn on the phone. Then connect the iPhone to the WiFi. Take the sim card out, and put if back in ;)
Hopefully this will resolve the problem.
by
Add a comment
Your problem could come from 3 sources.
The first one is a software problem: just try to make restore with iTunes.
The second one could come from the sim reader commutator. If this commutator doesn't make contact, the iPhone will think that there is a sim in your slot. So you have to join them together. And after, you have to check if it's separates when you put your trap inside.
The third one is: you haven't properly plugged your antenna cable on the antenna connector.
Score 1
1 Comment:
Thank you so much for the second option, I know it's a very late reply, but this helped me SO much. After getting water in my iPhone 6, I thought the SIM slot had stopped working! Thank goodness for this otherwise I would've thought I needed to desolder and resolder things to fix it! It finally recognized when the SIM was and was not in the slot. Thank you so much!
by
Add a comment
Add your answer
Ben will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 6,778
