Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Replaced home button, now display doesn't work.
Display won't work, phone rings, seems to power up normally and is detected by iTunes. I followed the guide to install a new home button and the display hasn't worked since.
Comments:
Thanks for the tips. Still not working. I think I may have damaged the flex cable.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Reset, hold both home and power button until the iPhone begins to restart. If fixed done. If still no display after Reset then, you need to retrace your steps and carefully reconnect the LCD Display Connector to the Logic Board perfectly.
Add a comment
if not working after connector check, check the flex...
inserting the flex in the slot in the frame, many people bend or pinch the flex .... check you have entered it correctly, it could be remained folded behind the glass ...
sorry for my english :)
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 599
