About dual hard drive: do I have to swap the native HDD with the SSD?
I'd like to keep my original HDD and replace the optical bay by a SSD.
I know that the SSD should be used to host the operating system but should I swap the HDD ? Meaning, should I replace the original HDD by the SSD and place the original HDD into the optical bay ? Or can I just add the SSD into the optical bay without speed loss or booting issue ?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Hi,
1.- You want OSX on the SSD as it would run way faster than on a HDD.
2.- I dont know if you might have to swap positions because you could just define that it boots from the SSD that would be on the Optical Drive bay without seed loss or booting issues.
Score 1
Add a comment
I/O speed and booting are to reasons people swap things around. If you want the SSD to be the bootable volume you must use the HD SATA connection, then put the HD in the optical drive accessing it's connection.
Score 1
Comments:
Thank you for your input, I successfully performed the update! :)
by
Add a comment
Add your answer
Francois Massart will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 842
