How do I fix frequent video buffeting and frozen images?
I watch Netflix and the video frequently buffers or the image freezes or becomes fuzzy
Cancel
Comprehensive repair manuals on all portable tablet computers by Apple. Repairs are likely to require heat and careful prying.
Rep: 1
Your network connection is not able to sustain the stream rate and/or is dropping on you.
Check your WiFi AP are you close enough to it? Also check to see if others are also running WiFi AP's near you you maybe fighting for the same bands. Look at changing your band if you can.
If your connected over your cell service then the location of the nearest tower and the number of others connected to it can cause this as well. Talk with your cell provider for help. You may not be able to get anything better.
Check your wired network are others in your household fighting for bandwidth? Your network provider (cable or other) may not have provisioned the line correctly (very common) and/or your exceeding what you were provisioned. You may find a given time during the day is worse than another if so your provisioned allotment is not being met.
Lastly, things happen! the connection thru the Internet to Netflix's servers may not be able to sustain all of the people connected at the given time.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 181
We have a chance to guarantee our right to repair electronic equipment—like smartphones, computers, and even farm equipment. This is a once-in-a-generation chance to protect local repair jobs—the corner mom-and-pop repair shops that keep getting squeezed out by manufacturers.
Join the cause and tell your state representative to support Right to Repair. Tell them you believe repair should be fair, affordable, and accessible. Stand up for your right to repair!
