Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Why don't my internal Mic and speaker don't work anymore?
I had to open my iPhone because it was dusty between the glas and the display. by following he guidelines everything worked out fine. But unfortunately now the integreted mic. and the speaker don't work anymore. Loudspeaker and Headset with mic are working fine.
Please advise
Score 1
2 Comments
You had your device listed as an iPhone 6G. There is no such thing as this. Can you tell us what model your iPhone is?
by
oops. it's a iPhone 3G of course.
by
Add a comment
Most Helpful Answer
Make sure ribbon number 4 is connected. Disconnect and then reconnect. You can look in the tutorials to see where number 4 is if you dont know or if its not labeled.
Score 1
Add a comment
Sounds like a pinched/damaged or not fully connected at one or both ends.
Add a comment
Add your answer
Andreas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,400
