Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
301 Questions View all
Battery removal, torn black outer material - dangerous?
I'm changing the rear, aluminium casing on an iPad 2 which obviously involves prying up the battery from the large amount of adhesive that it's stuck down with.
I did this as carefully as possible, but a small amount of the black material or 'film', that covers the battery was left behind on the old casing adhesive.
This has exposed a small area of the battery (I can see a silver layer underneath) and the battery also now has a 'chemical' or 'solvent' smell to it.
The three cells have also bent very slightly during the removal process (it seems almost impossible to me to get them out perfectly flat)
Is this battery still safe to re-use or do I need to buy a replacement?
If I do need to replace it, is it safe to store inside my house in the mean time or is there any risk of fire/explosion?
Thanks in advance for any advice.
Score 2
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
If it is a strong chemical smell then I would replace it without thinking twice. It's not worth the risk. I have seen damaged batteries reused in ipods and it never turns out well.
Score 3
Add a comment
Time for a new set of cells - Even if the cells are not leaking now you have a hole which the chemicals can leak out and if the metal contacts the case things could also short out.
A time bomb waiting to go off!
Score 2
Comments:
So then, how should I dispose of a torn battery?
by
Contact your local battery recycler
by
Add a comment
If you can smell it, you need to replace it. We've had an iphone 4s battery explode in our shop. Not something you want to happen ;)
Score 1
Add a comment
Add your answer
simon evans will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 174
All Time: 4,716
