First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Questions View all
Question Closed
Can I install iPad 3G digitizer in iPad Wifi?
Hi,
I am trying to replace broken iPad digitizer. I ordered the part from Amazon (iPad Digitizer with mid frame for Wifi only iPad). The seller ended up sending me the 3G version. I asked for an exchange but he claims that I can just cut the 3G antenna cable off and it will work without any problem. Says it's cross compatible. Is that true? Should I give it a go or insist on exchange/return?
Thanks,
Harris.
Add a comment
1 Answer
Chosen Solution
It is glued on there pretty good. It is possible to remove it and the rest of the frame is identical to the WiFi version. On the other hand it's the sellers responsibility to send you the correct item. Is he going to fully reimburse you if it goes wrong? Probably not, I would exchange it.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 853
