Where are the spark plugs in a Mitsubishi Galant 6G75?
I need to change the spark plugs on the 2005 Mitsubishi Galant 6G75 engine. I found the 3 spark plugs up front, but I need to know the location of the other 3.
josecruz10, here is what I get " Disconnect the negative wire from the battery. You need to remove the engine cover to get to the front 3, pull out the spark plug wires with your hands, one at a time. make sure that you put them back were you pull them from. go to pepboys and get yourself the soket for spark plugs. To get to the other 3 you need to remove the manifold "the silver thing with big lines" under the manifold which will take you about 30 to 40 minutes are the other plugs, do the same thing. from here
If he pulls the manifold, will the gasket need to be replaced?
@mayer, I would most certainly replace it, so as to avoid vacuum leaks later on.
I aure appreciate your response "oldturkey03"! Thanks.
you are welcome :) good luck.
Dear sir what type of plugs should i fit to suit this engine and higher millage.kind regards
I'd use NGK FR6EI or DENSO K20PSR-B8
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,337
3 Comments
oldturkey03
sir - I have removed all that needs to be removed around the :silver manifold. However, I cannot remove the manifold. Do I need to give it a little "whack" with a hammer or hard object to pry it loose? It just wont budge. Thanks in advance for your help.
by josecruz10
It may just be sitting tight on the gasket, a careful shaking might loosen it up. Definitely make sure you removed all the nuts and bolts. I might find a service manual.
by oldturkey03
Here is a great write up....
by oldturkey03
