Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
Whys is my iPhone 4 display showing darker areas and scanlines?
I opened my iphone to change a broken dock connector and the volume switches now they work but I have a new problem.
I'll do my best to expain... There seems to be an inconsistency in the intensity of the brightness. It seems like the dark areas are being brighter than they should.
However, whenever there is something very bright, like white or close, in the horizontal bands that contain the white areas, the intensity of the black areas enclosed look correct.
Do you think I need to replace the lcd assembly or could it be easier?
I know, it's tricky to explain so here are some pics. Unfortunately I couldn't get to photograph the scanlines.
Thanks in advance!
Add a comment
1 Answer
Chosen Solution
Have you checked all the display connectors. Many times if there are any issues with a phone after a repair it is because something was loosened or not properly reset. I would check all the connectors inside an look for any debris that could be causing problem by shorting electronics out. i had a similar problem on an iPad and it was because a small metal shaving was shorting out the backlight connector. Just look over everything and tell us what you find and we can help you from there.
Hope this Helps
Add a comment
Add your answer
baltxo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 880
