Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
305 Questions View all
replace AirPort with mSATA SSD?
Hi all,
does the iMac 2011 read mSATA SSD at the AirPort "mini PCIe" Slot?
or is it not working?
Add a comment
Chosen Solution
No - it is a dedicated network connector, not SATA, there are no expansion ports, only a SDXC SD Card slot.
If this answer was helpful please remember to return and mark it Accepted.
Score 1
Add a comment
The AirPort card in earlier models can be replaced with other cards. I have used MPX-1132 dual sata controller successfully. I did research mSATA SSDs. If I remember correctly, some will work; they will definitely not be bootable.
Add a comment
ehhh you might be better off using the thunderbolt port and adding one of those boxes with pci-e slots. those btw should be bootable if the hardware is compatible with mac.
there are some sata cards that are mac compatible, however this means one big box on your desk more
as for the mpci-e slot it looks like a standard one, if you can find a (m) pci-e sata adapter that is compatible with mac you should be able to add 2 ssd's however the room requirement kinda get's problematic unless you do some heavy cable hacking you'd have a hard time of it.
GL
My $.02
terramir
Add a comment
Add your answer
skdubg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 2,007
