Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
Where and how to install home button when no retainer?
Two things:
#1 So my home button doesn't work. After looking inside, the retainer that houses the home button ribbon cable isn't there (please see uploaded pictures - resolution slightly fuzzed). What are my options.. how do I affix the end of the cable to its contact point without the retainer? Is there some adhesive or creative solution to pin it down.
#2 I ordered a new digitizer/lcd display assembly, battery, among other things. After installing each part, the iOS won't boot. I don't get the silver apple logo when pressing the sleep/power button - just a black screen with backlight for a few seconds. When I plug the phone via usb it's able to sync and communicate with iTunes. Very frustrating. Your thoughts on solutions much appreciated.
Thanks!
Add a comment
1 Answer
Chosen Solution
If a retainer is missing you have to replace it which means you need to install new charging dock.
About your screen, two things might happened.
1. You damaged the LCD or it came damaged.
2. You damaged the board. Next to LCD connector there is a bunch of small resistors. You get a blank screen if you damage one of those resistors.
1 options is easily solved with new screen. Option 2 is a little bit more complicated.
Hope this helps.
Comments:
Thanks for boiling it down. The charging dock sounds like it'll do the trick. resistors appear intact, ill have to order both and see. updates to come
by
Add a comment
Add your answer
not will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 445
