5th generation of Toyota's modern full-size sedan.
62 Questions View all
How do I change the front parking light bulbs?
Both front parking lights are blown. I can't change them without removing the parking light assemblies. Under the hood there is a white tab on each one with a small phillips screw. I removed those but the assemblies still won't come out. What are my next steps ?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Mark, follow this:"
1 Open the hood on your Toyota Camry and locate the parking lights. They are on the outside of the headlights toward the front fender.
2 Remove the clip, if your year Camry has one, that protects the bulb ballast. Pull up on the clip to remove it.
3 Remove the electrical plug running to the bulb ballast. Squeeze the release tab on the electrical connector and pull the plug off.
4 Turn the bulb counterclockwise to unlock it and pull it out of the housing.
5 Install a new bulb. Installation is the reverse of removal." from here. There are more directions on here as well. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,123
