The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
670 Questions View all
Playstation 3 won't stay on?
My sister left my PS3 on for over a month on pause. After I turned it off, it refuses to stay on for more then a couple of seconds.
Comments:
I have a similar issue. When I turn on the system on, I hear a beeping sound and then the system shuts down right away. Nothing has a chance to show up on the tv. It is an older system (first generation). Does it pay to try and repair this or buy a "new" system.
by
Add a comment
1 Answer
Chosen Solution
Might be a heat issue... If its the old model (non-slim) PS3 then it may just need to be cleaned out with a can of air. Also check to see if the fan is working, when you turn the power on check to see if you feel any air coming out the back of the system. Hope this helps.
Comments:
thanks I will try that
by
I have the same problem. When I attempt to turn it on the green light comes on and the fan starts. It immediately turns off with a flashing red light. Pressing the off for a few seconds will again make the red light go solid.
by
Add a comment
Add your answer
Erica Garces will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 34
Past 30 Days: 112
All Time: 5,531
