Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
539 Questions View all
Popped Off Key Caps - how do I re-install them?
Splashed a bit of beer around the right-hand side of my MBP keyboard but wiped it off immediately. Am certain some of the liquid seeped between the key caps, but it was working fine until about a 2 hours later, when it would automatically capitalize all letters.
I then shut it down, then rebooted it.
Bad Move: It now comes up on safe boot, and asks for my password - which has a mix of lower case, caps and numbers. So I can't get in.
Anyway, I went through the articles here on Ifixit on another computer and found what I should have done.
Anyway, one of the suggestions was to pop off the key caps - which I did - and dry them out. Now, I can't seem to return them!
Any pointers?
TIA
TakeTwo66
Score 1
Add a comment
Chosen Solution
LMGTFY
If this answer was helpful please remember to return and mark it Accepted.
Score 3
Comments:
Thanks so much! The link helped me click them back to position - except for one more key.
Sadly, my MBP now types everything in uppercase. Thinking of doing a full take down and go in with some contact cleaner.
Thanks again!
by
Be careful what you use so as not to etch the circuit board. REALLY DRY IT OUT with a 99% denatured alcohol pass and a desiccant before reassembling.
by
Thanks again! Will order the tools - can't get the battery out of the way. Have to contend with having an ALL CAPS mac meantime (no numbers for me).
On a different note,newby question: how do I mark the answer as 'accepted'?
EdwinH
by
I'm lost, sorry - can't find the tab for 'actions' ??
by
Add a comment
Hey I used this site a while ago when I had the same problem: http://www.laptop-keys.com. I ended up trashing the plastic clip and had to get a new one but I remember it only being $3-something. You may need to do that.
Comments:
Thanks, Barry. I ended up ordering the OEM keyboard from Ebay (less than $30) -- and had the local apple accredited service shop do the diagnosis and installation for $56.00. They did it in 4 days!
I could have spent less if I did not ask them to diagnose - but had to be sure nothing else was corroded since it was more than a month before I got the keyboard.
So far, no issues. Much cheaper than buying the upper keyboard assembly.
Cheers!
by
Add a comment
Add your answer
Edwin H will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,230
