Repair guides for the MacBook Air, Apple's current line of consumer laptops.
4816 Questions View all
Question Closed
MacBook Air logic board error, no boot & no charge?
Hello,
I have a first gen Macbook Air, it is not able to boot, and not able to charge.
The problem is not the charger, i have tried it charging with my MBP ac adapter and it didnt work also, not even the green light shined.
After removing the lower case, i saw that one component of the logic board is burned out.
I have added two pictures to show that part.
(not original ones, i have no cam)
This is written on the component 0806AJ
Logic board, Red marked component that is destroyed
Closer view of the destroeyd component
I am a student and cant effort a new logic board.
Can this problem be solved with just replacing the component that is destroyed?
And what is that component?
Thanks and greetings from austria
Niki
1 Comment
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Chosen Solution
Soldering logic boards is not really a DIY task - it takes lots of experience (practice) special tools and solder. You might be able to get someone locally, on e-bay or even Apple to repair the logic board. If you can get Apple to give you a "depot repair" it would be the best bargain you'll find. You'll have to investigate/compare prices only you know your budget.
If this answer was helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 694
