Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
iPhone 3G won't boot up!
Hello,
I have an IPhone 3G, 2.2, baseband 2.28. I used Quickpwn to jail break and then used yellowsn0w to unlock through cydia. It worked fine for a months, then just simply wont boot up, it displays the apple logo for a few seconds statically and doesn't boot up.
Please let me know if there is anything i could do. Also, I tried a hard reset to no avail it just turns off. I also tried connecting it to itunes and it doesnt seem to be detected by itunes. This is a nightmare, please help if u ca
Add a comment
1 Answer
Chosen Solution
I have not used Quickpwn or yellowsn0w on a 3g before, how I usually do it (and will probably fix your problem) is restore the phone to stock ios through iTunes then jailbreak with Redsn0w (and flash iPad 06.15.00 baseband if needed) to the device.
Once the Jailbreak is done, launch cydia and let it update (you will need to either turn off the screen sleep in the settings or make sure the screen doesn't go to sleep while updating). The reason for this is the 3G is a slow iphone (compared to today's standards) and the cydia update doesn't seem to run in the background when the phone screen is in sleep mode (atleast thats what i have found. Once it's updated, search for Ultrasn0w in cydia and install it, reset phone and your phone should be unlocked and on the 4.2.1 software (latest software available for iphone 3G)
Keep in mind that if you update the phone through iTunes, that may update the baseband. If you want to retain the baseband, use the option to make a custom ios through redsnow before you update the iphone. A good website for iPhone jailbreak info is www.redmondpie.com or whack the word redmondpie in google alone with your search term ie. "iphone 3g jailbreak 4.2.1 redmondpie"
I thought i would post a reply just to get the ball rolling for ya ;)
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 963
