Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
565 Questions View all
What could be wrong with iMac display backlight other than CCFLs?
My iMac 20" (early 2008) recently lost all backlight. Here are the symptoms:
1) On startup, and on wake, the screen reaches full brightness for less than a second, then goes dead. This is why I think the CCFL's themselves are not the problem, but rather something that is supposed to be powering them.
2) For the past year, the screen simply went dimmer than usual, rather than going out completely. So I suspect that something half-broke a year ago, and is now fully broken.
3) Shining a light on the screen reveals that the LCD itself is working just fine. Also, my external monitor works, so at least the video card is probably okay.
Things I've already tried:
Resetting the SMC, PRAM and NVRAM
Are these symptoms consistent with a specific known problem? Is there anything else I could do to try to diagnose what the issue is? I'd rather not start replacing parts that aren't necessarily broken.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Replace Apple part # 922-8507 (inverter board). To test to see if this is the issue, hook it up to an external monitor. If the external is good, replace the part.
Score 4
Comments:
Thanks for the suggestion! I will check this out.
by
Wow... two months on back order but it finally arrived, and it worked! Thanks!
by
Add a comment
Did you try booting on the Safe Mode? Does the same issue return?
Comments:
I tried booting in Safe Mode, but the screen problem is unchanged.
by
Add a comment
Add your answer
Donny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,489
