Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3252 Questions View all
Why is my screen ALMOST white of the dead?
Hello tinkerers,
After having unmount/mount my iPhone to fix the power button, my screen became white (Commonly called White screen of the dead).
But it's different from the thousands of topics on the Internet which talk about this issue.
- The iPhone is working (I can do everything with it).
- The screen was totally white, but now it's becoming day after day less white and more visible => it means I can now see the applications etc, but with difficulty. here is a screenshot to show you that: LINK
- Funny thing: Everything is displayed in black and white! It means, if I go to Settings/General/Accessibility and I turn on the white on black mode... everything will now be displayed in color !
Of course I checked that all the connectors are well connected to the motherboard (particularly the LCD one) etc.
My only assumption: maybe the connection is not good enough and I should clean the LCD connector with alcohol.
To sum up: Nothing is broken, the LCD screen is working but we can barely use the iPhone because the screen is 90% white. (Please check out the picture I attached to understand what is happening)
Thank you !
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Sounds like a bad lcd connection to me if it is getting better.
Add a comment
Add your answer
Sylvain will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 473
