Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1401 Questions View all
Why my MacBook does not power on at all?
Here is the deal: The power adapter is working great, so the battery, fully charged. But when i hit the power button, NOTHING happens, no lights, beeps, anything.
I´ve already checked the conection cable of upper case to logic board and it seens to be fine. What should I do?
Add a comment
Chosen Solution
Try clearing it out. Here's how:
How to Clear the PMU 1. Step 1 Quit all of your active applications and shut down your Mac. 2. Step 2 Once your computer is completely shut down, disconnect the computer's AC power Adapter and remove the battery from your Mac. 3. Step 3 Press and hold down the power button on your MacBook or MacBook Pro for at least five seconds and then release the power button. 4. Step 4 With your Mac still shut off, reinstall the battery in your MacBook or MacBook Pro and reconnect the AC Adapter. The PMU/SMU has now been reset on your computer.
Next try resetting the PRAM. Start up and immediately hold down the option - command and the "P" & "R" keys. Wait till you hear three tones, then let it try to start up.
Score 5
Good place to start +
Add a comment
When you connect the AC adapter to the laptop, what color is the light on the AC plug? Does it appear to charge the battery? Or is there no light at all? Knowing this info will help determine whether or not your laptop is basically intact, or experiencing more severe issues.
I would remove the battery during troubleshooting in order to avoid complicating the situation. Also, definitely test the RAM -- reseat both modules, and then try powering on with one module in place, and then if that doesn't help, move it to the other slot, and try again. Lots of these machines suffer from a bad RAM slot and won't turn on when memory is in that slot.
Otherwise, try resetting the PRAM like Mayer suggested...sometimes that can "wake up" a machine.
If none of this helps -- and especially if there is no light on the AC plug -- you'll want to remove the topcase and see if you see signs of liquid damage, i.e. corrosion. If so, clean it off with q-tips and 90% rubbing alcohol, let the machine dry, and see if that makes a difference.
Score 2
+ good suggestions
Add a comment
Add your answer
Eduardo Xavier Manfredini will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,626
