Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
274 Questions View all
Is second hard drive possible in with opti bay?
I have a 20" white imac with 2.0ghz core duo processor.
My question is, can I remove the optical drive and install a second hard drive with the opti bay option? I see there is an opti bay drive available but it say for core 2 duo only.
Whats the difference and what would stop it from working?
I am also upgrading the cpu to a 2.16ghz core 2 duo and was wondering if I could bump this one to 2.33ghz and what model processor would work for me?
Thank you for your time.
Oh, one more thing. What is the connection called on the optical drive? I know its not SATA.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Yes, replacing it is definitely possible. You'll need this particular enclosure that we sell. If I recall correctly, I believe the interface is Apple's proprietary IDE connector.
Follow the instructions for removing the optical drive, and before installing the optical bay enclosure, remove the plastic plate from the enclosure. You need to remove it, because it blocks some of the optical drive bracket's mounting pins.
Add a comment
Add your answer
sold4money will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,002
