13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
No more sound from my speakers, red light flashing
The sound of my MacBook has suddenly stopped working, I can't change the volume, I hear nothing and there is a 'white prohibiton sign' when I try to change it.
Also there's at the leftside a red light flashing, where normally I put my headphone in.
I've already looked at my 'system preferences' but also there: bad luck!
Does anyone know a solution for my problem?
Score -1
Add a comment
1 Answer
Chosen Solution
Laura, apparently it's a common problem in some MacBooks and MacBooks pro.
The audio jack is a combined optical/analog audio jack.
When the optical audio light (the red light) turns on it's because it believes you've connected an optical audio peripheral, so the regular audio and speakers stop working.
Some people have successfully resetted it by fiddling with the optical audio sensor inside the jack with a toothpick.
Read this thread:http://discussions.apple.com/thread.jspa...
It's from 2006, but if you go to the last posts, you can see people are still having the problem.
My previous MacBook Pro had it, but i didn't manage to reset it. A lot of people have tho, so it might worth a shot.
Good luck.
Score 1
Add a comment
Add your answer
Laura Huysmans will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,326
