Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
830 Questions View all
How should I repair a dinged up LCD screen case?
Macbook Pro 13" LCD screen case Nov 24 @ 4:26 PM
Hey,
The aluminum case of my screen has serious scratches and some dings...had an accident yesterday!!
I am really annoyed by that!!
I have seen they offer upper and lower cases for the macbook, but I couldn't find any case for the screen!
Does anyone have any ideas where to get a new screen casing, or maybe something to get rid of the scratches?
Thanks a lot,
Max
Score 1
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
The Macbook Pro 13" LCD display is hard to dismantle. With the iBooks and PowerBooks and even plastic macbooks models it was easy to swap the panel case, only 2 or 4 screws to unscrew and the job was done but with the unibody MBP 13"/15"/17" Apple made it more difficult. You need to heat the glued front glass to take it out and have access to the screws that retain the LCD screen. Doing this would probably void the warranty if you still have one and you could also damage the LCD if too much heat is applied to the screen. A complete LCD display swap would be more secure but would also cost much more.
Score 2
Add a comment
Display case or back is what you're looking for. There are some here on occasion, also on eBay, you might be able to pick up a pretty good case from a water damaged Macbook.
Good Luck,
N.
Score 1
Add a comment
sandpaper to get sharp edges off, get a uniform look,
paint it and have a custom MacBook ;)
Add a comment
Thanks for the answers! I couldn't reply before cause my school blocked this site!!
I think I will keep looking on ebay for an occasion to buy a complete LCD display!
Add a comment
Add your answer
maxeyy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,835
