<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Samsung DVD Player&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/Samsung_DVD_Player?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Samsung DVD Player&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 03 Aug 2026 11:00:48 -0700</pubDate>
<item>
<title><![CDATA[Samsung DVD Player: accepts disc but stays on load will not play]]></title>
<description><![CDATA[<p>Samsung p231 dvd player  accepts the disc and the door closes but the indicator window shows loading and will not start playing</p>
<p>⟐ Commented March 31, 2024 at 13:52 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/120411/accepts+disc+but+stays+on+load+will+not+play</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/120411</guid>
<pubDate>Sun, 31 Mar 2024 13:52:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: switch on and it says( PROT )and goes of?.]]></title>
<description><![CDATA[<p>switch on and it says prot and goes off</p>
<p>⟐ Commented September 05, 2024 at 12:02 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/165146/switch+on+and+it+says(+PROT+)and+goes+of.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/165146</guid>
<pubDate>Thu, 05 Sep 2024 12:02:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: It won't turn on how can I fix it]]></title>
<description><![CDATA[<p>How can I fix my DVD player that does not turn on?</p>
<p>⟐ Answer accepted July 14, 2024 at 8:04 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/401927/It+won&#039;t+turn+on+how+can+I+fix+it</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/401927</guid>
<pubDate>Sun, 14 Jul 2024 08:04:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: DVD player reads some discs but stop reading and playing others]]></title>
<description><![CDATA[<p>My Samsung DVD player makes loud noises while playing certain discs bit runs smoothly with others.  It also freezes in the middle of playing certain discs but plays others all the way through with no problem.  It has recently completely stopped reading and playing certain discs that were playing fine before.  What could be causing this issue?  Is it time to replace it?  It was given to me by my sister.  I don't think she's had it longer than a couple years.</p>
<p>⟐ Commented July 24, 2023 at 3:44 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/359049/DVD+player+reads+some+discs+but+stop+reading+and+playing+others</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/359049</guid>
<pubDate>Mon, 24 Jul 2023 03:44:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: volumin down on its own]]></title>
<description><![CDATA[<p>the volume on my Samsung DVD/Blu-Ray player keep going down to 0  on its own  and when trying to volume up it will but then volume down again on its own on my samung dvd bluray player.</p>
<p>⟐ Commented March 20, 2025 at 18:33 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/277454/volumin+down+on+its+own</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/277454</guid>
<pubDate>Thu, 20 Mar 2025 18:33:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: play for some second, then write fan-ng and then stop.]]></title>
<description><![CDATA[<p>When I plugs my Samsung ,it will play for some second, then write fan-ng and then stop. want can cause it</p>
<p>⟐ Commented September 27, 2025 at 8:08 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/575409/play+for+some+second,+then+write+fan-ng+and+then+stop.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/575409</guid>
<pubDate>Sat, 27 Sep 2025 08:08:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung BD-JM57C: Tray will not open - Home screen comes on and off intermittently?]]></title>
<description><![CDATA[<p>This device is a ‘BD-JM57’  -[-  We don’t see any ‘C’  in the model no.  Not sure of any difference with that, but it surely does look identical.</p>
<p>Plug it in and we hear the dvd player try to open but it will not.  The home screen (start up screen) pops up but immediately goes off.  It comes on and off intermittently each time we hear the dvd drive attempt to open .  Plugging in turns on player - no need to press on button anymore. . Cannot turn it off either.   We can manually open drive and shut it.  Here is what I’ve tried so far:</p>
<p>Disassembled &amp; examined the player.  Belt appears to be ok.  Disk spins - seems motor is ok.  It appears that the tracking mechanism is moving forward a little but stops and goes back and it’s quiet again (for a few seconds) and then it goes forward again to repeat the process over and over.  Each time home start up screen pops up for a second and goes black to start the process again.  I’ve unplugged both cables to dvd carriage just to see if player will work without dvd hooked up. DUH.  Tried this with both cables off &amp; tried one and then the other with no luck (as if that would actually work - Yet stranger things have happened in my decades of IT work).</p>
<p>The player is not that old (less than 2 years) and we rarely use it for cd/dvd use. 98% of the time we just use the apps.  Hate to have it end up in a landfill if there’s a way to save it.  I’ve had very good luck over the years fixing stuff, but I have failed with this one.</p>
<p>Really need this for local weather and the apps.  Is there any way to use without the carriage somehow?   Or any other ideas will surely be appreciated.   Hate to have it end up in a landfill if there’s a way to save it.  I’ve had very good luck over the years fixing stuff but I have failed with this one.</p>
<p>Another idea is a replacement for the dvd part?   It’s been so long since I’ve done repairs like this I don’t have a source for parts and don’t have parts list.   Would it be feasible to call Samsung for the part?</p>
<p>Thank you in advance for any help!</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_19_Num_2020" class="header">Update (06/19/2020)</h3></div>
<p>UPDATE:  Found the part:</p>
<p><a href="http://www.samsungparts.com/Products/Parts_and_Accessories/PID-AH96-02790A.aspx" rel="nofollow noopener noreferrer" title="http://www.samsungparts.com/Products/Parts_and_Accessories/PID-AH96-02790A.aspx">http://www.samsungparts.com/Products/Par...</a></p>
<p>But $83 +_tax + shipping ?!  Whoa!</p>
<p>⟐ Commented July 19, 2021 at 14:14 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/641823/Tray+will+not+open+-+Home+screen+comes+on+and+off+intermittently</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/641823</guid>
<pubDate>Mon, 19 Jul 2021 14:14:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: HT-F4500/2A DVD Player spins disk, outputs sound, but know video]]></title>
<description><![CDATA[<p>This DVD player has always work fine until recently.  Now if you put a DVD in (several have been tried) I can get sound output and the counter indicates that the DVD's are playing but I'm not getting any input to a monitor or TV via the HDMI connector (several HDMI cables have been tried).  The monitor will indicate power is being passed to it when the DVD player is turned on and will occasionally a screen flash will appear briefly with no visible information.<br /><br />The case has been opened and the HDMI connector appears to be solidly connected to the board.  <br /><br />Only issue I can recall that might have some bearing is that a Spectrum Tech was out to repair one of their Cisco cable boxes and additionally replaced a TiVo cable card (which he knew little about the TiVo box and didn't need replace), but to get to it he pulled both the TiVo and Samsung BlueRay/3D player out to swap the cable card, it's possible that he placed a strain on the HDMI cable at the time.  I can't verify that the it was working before that, but do it hasn't worked since then<br /><br />Any ideas on how to further trouble shoot this issue would be appreciated.</p>
<p>⟐ Answer edited January 19, 2025 at 2:15 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/884331/HT-F4500-2A+DVD+Player+spins+disk,+outputs+sound,+but+know+video</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/884331</guid>
<pubDate>Sun, 19 Jan 2025 02:15:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: Why won't my dvd player play in color?]]></title>
<description><![CDATA[<p>my dvd player won’t play in color, black &amp; white only</p>
<p>⟐ Commented December 23, 2020 at 17:23 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/622644/Why+won&#039;t+my+dvd+player+play+in+color</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/622644</guid>
<pubDate>Wed, 23 Dec 2020 17:23:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD-HD850 Player: Why does my disk tray not open?]]></title>
<description><![CDATA[<p>Disk tray is not opening and I do not know why.</p>
<p>⟐ Commented November 22, 2015 at 22:39 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/200019/Why+does+my+disk+tray+not+open</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/200019</guid>
<pubDate>Sun, 22 Nov 2015 22:39:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: play for some second, then write fan-ng and then stop. HT-D5200]]></title>
<description><![CDATA[<p>The fan has only 2 wires and model is HT-D5200</p>
<p>⟐ Answer accepted April 02, 2024 at 8:28 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/730569/play+for+some+second,+then+write+fan-ng+and+then+stop.+HT-D5200</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/730569</guid>
<pubDate>Tue, 02 Apr 2024 08:28:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: Technical Info for Samsung DVD Player]]></title>
<description><![CDATA[<p>How can I get hold of technical information for a samsung dvd player model e234 (about 20 years old) including a circuit diagram? I have tried the samsung website with no success.</p>
<p>⟐ Commented January 20, 2023 at 14:51 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/765119/Technical+Info+for+Samsung+DVD+Player</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/765119</guid>
<pubDate>Fri, 20 Jan 2023 14:51:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: It won't turn on]]></title>
<description><![CDATA[<p>DVD player just won't turn on, was working fine the day before and the next day, nothing.  It's plugged into the wall, the outlet is working fine.  Tried turning it on with remote and power button on device and nothing.</p>
<p>DVD inside player.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/421082/It+won&#039;t+turn+on</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/421082</guid>
<pubDate>Thu, 24 Aug 2017 08:48:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: Why does my DVD Player turn on and off by itself?]]></title>
<description><![CDATA[<p>The Player just turns on and off for no reason.</p>]]></description>
<link>https://www.ifixit.com/Answers/View/222805/Why+does+my+DVD+Player+turn+on+and+off+by+itself</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/222805</guid>
<pubDate>Thu, 09 Apr 2015 09:06:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: Why does my Samsung DVD Pla play in black and white, instead of color?]]></title>
<description><![CDATA[<p>Samsung player will not play in color.</p>
<p>⟐ Answered February 14, 2018 at 12:16 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/462291/Why+does+my+Samsung+DVD+Pla+play+in+black+and+white,+instead+of+color</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/462291</guid>
<pubDate>Wed, 14 Feb 2018 12:16:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: Why is my Samsung DVD player just showing on with out loading]]></title>
<description><![CDATA[<p>Why is my Samsung DVD player just showing on with out reading</p>
<p>⟐ Answered April 07, 2024 at 13:42 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/843685/Why+is+my+Samsung+DVD+player+just+showing+on+with+out+loading</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/843685</guid>
<pubDate>Sun, 07 Apr 2024 13:42:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD-HD850 Player: Why is my dad player not reading disc]]></title>
<description><![CDATA[<p>Disc spins and says loading but stops and says no disc</p>
<p>⟐ Answered June 06, 2026 at 8:56 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/958399/Why+is+my+dad+player+not+reading+disc</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/958399</guid>
<pubDate>Sat, 06 Jun 2026 08:56:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: DVD player will not load goes in and kicks back out]]></title>
<description><![CDATA[<p>Blu-ray player will not load  Disc enters, then gets kicked back out</p>
<p>⟐ Answered March 01, 2025 at 8:30 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/889486/DVD+player+will+not+load+goes+in+and+kicks+back+out</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/889486</guid>
<pubDate>Sat, 01 Mar 2025 08:30:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD Player: Doesn't switch on]]></title>
<description><![CDATA[<p>Won't turn on. Brand new never used been in box unopened for over 12 month so out of warranty.</p>
<p>⟐ Answered July 18, 2024 at 3:21 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/860007/Doesn&#039;t+switch+on</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/860007</guid>
<pubDate>Thu, 18 Jul 2024 03:21:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung DVD-HD850 Player: jvc dvd/vcr will not continue playback]]></title>
<description><![CDATA[<p>I have a jvc  dvd/vcr that will not continue playing. I have read the manual and followed it's instruction repeatedly. It says to disconnect the unit and power it off. I have tried this repeatedly to no avail.</p>
<p>I chose this category because it is the closest to my problem, I don't have a samsung and it is not just a dvd player, but a jvc  dvd/vcr player. I need to be educated on how to properly use this. Please help?</p>
<p>⟐ Answered August 12, 2023 at 5:16 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/442835/jvc+dvd-vcr+will+not+continue+playback</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/442835</guid>
<pubDate>Sat, 12 Aug 2023 05:16:30 -0700</pubDate>
</item>
</channel>
</rss>
