Toshiba Satellite L305-S5875 Keyboard Replacement
  1. Toshiba Satellite L305-S5875 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Keyboard Replacement: step 2, image 1 of 3 Toshiba Satellite L305-S5875 Keyboard Replacement: step 2, image 2 of 3 Toshiba Satellite L305-S5875 Keyboard Replacement: step 2, image 3 of 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: step 3, image 1 of 3 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: step 3, image 2 of 3 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: step 3, image 3 of 3
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  4. Toshiba Satellite L305-S5875 Keyboard Replacement: step 4, image 1 of 1
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  5. Toshiba Satellite L305-S5875 Keyboard Replacement: step 5, image 1 of 2 Toshiba Satellite L305-S5875 Keyboard Replacement: step 5, image 2 of 2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. Toshiba Satellite L305-S5875 Keyboard Replacement: step 6, image 1 of 2 Toshiba Satellite L305-S5875 Keyboard Replacement: step 6, image 2 of 2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. Toshiba Satellite L305-S5875 Keyboard Replacement: step 7, image 1 of 1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
3 other people completed this guide.
Juan
109 Reputation
3 Guides authored
Cal Poly, Team 20-5, Maness Winter 2013 Member of Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
4 Members
10 Guides authored
One Comment
It's not so easy to do step 3.
Texas Chick - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,185
