Introduction
The mother board is the heart and soul of this device. Everything from the operation system to the camera and audio port runs through the motherboard. If either component is faulty then the whole mother board needs to be replaced. This guide will help show you how to replace the motherboard right in your own home.
Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
After following how to remove the battery, unscrew the five 1.2mm Phillips Screws on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps.
3 other people completed this guide.
2 Comments
What information are you looking for?
