Introduction
Provides power to the machine and includes all ports on the left side of the machine.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Use a spudger to disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
52 other people completed this guide.
One Comment
Just successfully completed this repair. The guide is absolutely spot on with very clear high resolution pictures. I was working very carefully through each step and had no issues at all throughout the process until the very end when I couldn't find the last screw for the ram cover. Luckily it was stuck to the magnetic MagSafe charger port on the side of the I/O board!
I personally would rate this as a moderate repair instead of a difficult one as there is no specialist skills required like soldering. Thanks again!
