MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement
  1. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 3, image 2 of 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement, Battery Connector: step 4, image 1 of 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 5, image 2 of 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 6, image 1 of 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement, Display Assembly: step 7, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement, Display Assembly: step 7, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement, Display Assembly: step 7, image 3 of 3
    • Carefully peel the rubber fan bumper from the edge of the heat sink to expose the iSight camera cable adhered to the fan.
    • The fan bumper wraps around the heat sink and fits into the fan duct slots. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 8, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 8, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 8, image 3 of 3
    • Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  9. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 9, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 9, image 2 of 2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  10. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 10, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 10, image 2 of 2
    • Peel the iSight camera cable up off the fan housing.
  11. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 11, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 11, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 11, image 3 of 3
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • During reinstallation, be sure to fully reseat the display connector tab.
  12. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 12, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 12, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 12, image 3 of 3
    • Remove the rubber hinge covers from the right and left display hinges.
  13. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 13, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 13, image 2 of 2
    • Remove the two 4.2 mm T5 Torx screws securing the aluminum hinge brackets (one on each side of the Macbook).
  14. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 14, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 14, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 14, image 3 of 3
    • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
    • During reassembly, the vertical portion of the bracket should be in line with the aluminum rail in the center of the Macbook.
  15. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 15, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 15, image 2 of 2
    • Remove the four outer 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
    • Some models may use T9 Torx screws rather than T8.
    • If the rubber hinge cover adhesive is still on the screw heads, use tweezers to peel and remove it.
  16. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 16, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 16, image 2 of 2
    • Open the MacBook Pro a little wider than 90 degrees, and place it on end on the table, as shown.
    • While holding the display with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    • Be sure the display and upper case are balanced and will not fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  17. MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 17, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 17, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement: step 17, image 3 of 3
    • Grab the upper case with your right hand and rotate it slightly clockwise, toward the top of the display, so the display brackets clear the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Pull the display away from the upper case, minding any brackets or cables that may get caught.
164 other people completed this guide.
Sam Goldheart
465,762 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
35 Comments
I've been browsing guides to this model and I don't get how in this one on Youtube the laptop looks completely different, although it also claims to be A1502. Either one of them is a different model or I'm really missing something?
https://www.youtube.com/watch?v=lL4gpfcb...
Marina Gorobevskaya - Reply
Unfortunately the A1502 number isn't an exclusive model number, several devices share it, the internal differences between them vary. The more telling number is the EMC number, which tends to me more exclusive to unique devices.
Sam Goldheart -
After a closer look they actually seem to be the same, I just got confused by the video being a lot less detailed than this walkthrough. I just replaced the screen of my macbook following this guide (yay!) without any previous experience of fixing macbooks, though I must admit I assembled a few desktops at the dawn of the millennium. The only slight problem I encountered was that the main display cable wouldn't lie flat enough in that corner, it kept sticking out, and even after screwing the lid on the gap at that corner seems to be a tiny bit wider. But the laptop is working anyway.
Thank you Sam for posting this guide! It saved me a lot of time and money. Being in China I bought the display assembly on Taobao for $250US whereas the shop repair estimate that I got was around $400.
If anyone is still having doubts - you can do it!
The guide is very helpful. I managed to replace my screen within 1 hour. I bought my screen from ifixit too! the product is genuine and in good condition although it says that it has been used before! Highly recommended!
henrycwc - Reply
Can you replace just the LCD without the clamshell bezel and cables?
rickcostel - Reply
Past 24 Hours: 16
Past 7 Days: 122
Past 30 Days: 555
All Time: 188,405
