Introduction
This guide will show how to reattach the speaker cable to the Kensington Hi-Fi Headphones 33137 after the wires connecting the speaker cable to the speakers have been cut.
Start with no other headphone components attached to the speaker cable.
Before soldering the wires back onto the speakers, first the soldering iron must be prepared by cleaning the tip of the soldering iron with a damp sponge or rag.
Refer to the iFixit guide How to Solder and Desolder Connections for additional help with soldering.
After soldering iron is hot, touch the tip of the soldering iron to the end of the soldering wire. This will "tin" the tip of the soldering iron and will help to create a better solder.
Place the soldering iron back on its stand until it is needed.
With the wires placed in the correct position, the speaker and speaker cable wires are ready to be soldered.
Starting with one terminal, place the "tinned" soldering iron on both the terminal and the wire for 1-2 seconds. Then immediately place the soldering wire down on the terminal and speaker cable wire.
Repeat this process for each terminal on each speaker.
To reassemble your device, follow the Speaker Removal Guide instructions in reverse order.
