Nobis NB09 Battery Replacement
  1. Nobis NB09 Battery Replacement, Battery: step 1, image 1 of 1
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: step 2, image 1 of 3 Nobis NB09 Battery Replacement: step 2, image 2 of 3 Nobis NB09 Battery Replacement: step 2, image 3 of 3
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: step 3, image 1 of 2 Nobis NB09 Battery Replacement: step 3, image 2 of 2
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: step 4, image 1 of 1
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: step 5, image 1 of 2 Nobis NB09 Battery Replacement: step 5, image 2 of 2
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
3 other people completed this guide.
Jackson McAdams
390 Reputation
3 Guides authored
One Comment
where can i buy a battery from
Frederick Shipman - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,945
