Click Image To Zoom
iPad Wi-Fi Front Panel Assembly
$99.95
Product code: IF180-000-1
Product Overview
All the parts you need to replace your front panel glass.
  • Use this all-in-one assembly to replace your display glass, home button, and metal clips together.
  • This part will only work on a 1st Generation iPad Wi-Fi. For an iPad 3G, you need to use this part. We also sell front panel assemblies for the iPad 2 and iPad 3/4.
Assembly Components:
  • New glass panel with integrated touch digitizer
  • iPad Frame - connects the glass to the clips
  • iPad Display Clip Set - preinstalled on the frame
  • Home Button - preinstalled and built into the assembly
Compatibility
Identify your iPad
  • All 1st Gen iPad Wi-Fi models
Product Details
  $99.95
Condition:
New
Warranty:
6 month warranty
Add to Cart »
4 Available
Quantity:
Compatibility
iPad Wi-Fi
16 GB
32 GB
64 GB
Stories
My Problem
My sons dropped out iPad several times and it survived amazingly well until the last straw and then the display cracked.
My Fix
The repair went fine--about 90 minutes. Only confusing thing are those many small foam spacers which are semi-attached and I'm not sure which, if any, I'm supposed to keep. The instructions were silent about these little items. It appears the new unit comes with spacers, so I cleaned them out, but the instructions should probably make explicit mention of them.
Also, the instructions tell you to start prying in the upper right corner which is where the power button is and it seems like it's possible to mess up the power button with the metal spudger when digging around up there for the first time.
My Advice
This repair looks daunting, but don't be afraid. I would recommend a pair of angled tweezers to help guide the connectors back into the sockets when reassembling. They're a bit hard to reach with just fingers because you can't just open it all the way up--you have to hold it half-way closed for the connectors to reach the sockets.
As with all such things, read the instructions all the way to the end before starting!
