Click Image To Zoom
Installation Guide
iPod Touch 3rd Generation
Difficulty: Very difficult
Required Tools Add All Tools to Cart »
Spudger
$2.95 ·Add to Cart »
Metal Spudger
Soldering Iron
$24.95 ·Add to Cart »
Solder
$4.95 ·Add to Cart »
Share this Product
Stories
My Problem
We were too trusting of a CL seller, and believed her story about why the ipod wouldnt turn on (she said that she has to abort the software restore process in order to meet us at the appointed time, so it wouldn't turn on) , 'but it works just fine, trust me'. Yeah, right. It works just fine as long as it's plugged in.
My Fix
It went smoothly...the hardest part was opening the case. Directions in the guide were well-ordered and easy to follow. I have to admit, though, that I did depart from the guide at one crucial point. Once I got to the point of de-soldering and then re-soldering the battery connections, I took it to a local small electronics job-shop here in my town and paid them $10 to do that part. They had the proper tools and experience to do that fine, close work.(They used a scope) I would highly recommend anyone who is the least bit concerned about the soldering part to take that route.
My Advice
Just what I said- find an electronics place to do the actual solder work, if possible. Other than that, if you can read and follow instructions, you can have a sweet sense of satisfaction at a job you did yourself. Besides, don't you really want to see for yourself what that thing looks like inside?
My Problem
I use the iTouch daily, to listen Pandora and read the newspaper.
My Fix
The tools were broken before the screen removal.
My Advice
Be patient, and remove the screen carefully. Excellent instructions (step by step).
My Problem
Most expensive for me, anyway. my 3rd gen 64GB ipod went through a complete wash cycle. It started in my jeans pocket and ended up in the bottom of the washtub. After soaking in rice for a week, still no joy, so I took it apart to see all the pretty guts. Then left it sitting on the counter--in pieces--for 9 months. After it failed to spontaneously reproduce I decided to put it back together. Plugged it into outlet with power adapter and zOMG!!! It came on! But it wouldn't turn on if unplugged nor when connected to computer. Only hooked to mains power. Helpful people here suggested replacing the battery.
Sorry, no heroic tales of single-handedly fending off legions of rabid lemmings using nothing but the Lightsaber app on my iPod Touch (lemmings aren't too bright...)
My Fix
Instructions were dead-on. Repair went perfectly, not a single hitch. Desoldered old battery, soldered new battery in and it was golden.
Sadly, the new battery did not fix my lack of wi-fi. so it's kind of a hybrid Classic/Touch iPod: All the joys of a Touch, all the wi-fi of a Classic. oh, well. Still a lot cheaper than $400 for a new device.
My Advice
be absolutely certain to follow the directions! I got stupid and nearly ruined my screen by not using the spudger at the *correct* location, ie, *between* the clips. Stupid!
My Problem
Ipod touch got wet and never recovered after drying out thoroughly. Can't get the device to show any life. Normal reset procedure shows no activity at all.
My Fix
I thought the battery may be dead, so I replaced it. Did not help.
I did tear off the digitizer flex circuit in the process. Wow is that delicate! I have years of experience designing and assembling kapton flexes, and I have never seen such a thin and delicate flex as the ipod touch digitizer.
My Advice
It would have been helpful to have a mechanical cross section diagram of the ipod touch assembly to show how the various parts are attached. It would have made it easier removing the digitizer panel.
My Problem
The iPod was one year old, but was used too often. The battery wasn't holding its charge for more than a day - even without using it!
My Fix
I follow your guide, and to my surprise it wasn't too hard. The soldering part was a bit challenging but everything went good. Now the battery lasts like the new one.
My Advice
Try to remove the screen patiently. It might fell apart if you push too hard. It's a good thing if you solder the battery contacts before you set it in the glue that was left over in the metal parts. Overall, it's not a hard process, just a slow one. Good luck!
My Problem
I accidentally left my iPod on my patio overnight, and apparently, it rained a little bit. When I tried turning it on, it was completely dead. I put it in a bag of rice for 3 days, but it was still dead.
My Fix
The repair went perfectly. I ordered a new battery on a Monday, and received it on Wednesday. Thursday morning, it took about an hour to install the new battery, and the install went very smoothly.
My Advice
The only suggestion I have is maybe some helpful hints on reassembling the iPod Touch. It was a little tricky getting the display and cable back together.
Related Questions
| 2 Answers 0 Score | iPod touch 3g can only use with wall charger. |
| 1 Answer 0 Score | Battery compatibility and keeping 3.1.3 OS on older device. | |
| 3 Answers 0 Score | Why iPod touch not charging. But the apple sign comes on. | |
| 1 Answer 0 Score | Won't charge / no pc connection! | |
| 1 Answer 0 Score | Water damaged iPod touch, is it fixable? |
