Click Image To Zoom
Installation Guide
iPod Touch 2nd Generation
Difficulty: Very difficult
Required Tools Add All Tools to Cart »
Spudger
$2.95 ·Add to Cart »
Metal Spudger
Soldering Iron
$24.95 ·Add to Cart »
Solder
$4.95 ·Add to Cart »
Stories
My Problem
The rubber gasket around edge is sooo delicate. I had several pieces when finished.
My Fix
I will repair/replace gasket with bath tub calk.
My Advice
Need a better photo explaining the construction of front glass, plastic bezel and gasket.
My Problem
Ipod touch battery lost capacity over the years, decided it was time to attempt a replacement
My Fix
I generally consider myself a good fixer. This repair is accurately described as "very difficult." It was really, really hard to separate the front panel glass from the case. I ripped the delicate cable as warned in step1. I didn't realize it was ripped until reassembly.
I had no problem with the soldering or any of the other steps.
My Advice
Perhaps ifixit should sell dead devices that you could practice on before attempting the real repair.
My Problem
Bad battery...
My Fix
Not to good, hubbie must have been tired... Now the touchscreen is untouchable.
My Advice
Make sure hubbie, or other repairperson, is NOT to tired. Or do it yourself. The instructions where very clear, and the part about changing the battery seems to have worked.
Related Questions
1 Answer 0 Score |
Battery compatibility and keeping 3.1.3 OS on older device. |
1 Answer 0 Score |
iPod in water,,works when plugged in but not off battery |
2 Answers 0 Score |
iPod Touch wont turn on |
1 Answer 0 Score |
Why is my iPod not turning on when I charge it? |
2 Answers 0 Score |
Battery proper Current spec's |
