Click Image To Zoom
Installation Guide
iPod Nano 2nd Generation
Difficulty: Very difficult
Required Tools Add All Tools to Cart »
Spudger
$2.95 ·Add to Cart »
Metal Spudger
Soldering Iron
$24.95 ·Add to Cart »
Stories
My Problem
battery was running down. I was disappointed that the battery that once lasted nearly a day was only giving me 3 hours.
My Fix
It took 3 hours. It was kind of hard getting the case open and the battery was held in with strong tape. The battery wires were covered in hard to remove silicone and I didn't have any desoldering equipment. Also, I stripped one screw and lost another. I decided to put the remaining screws into areas that were easily accessible and forget about the others.
My Advice
Make sure you have good desoldering equipment and a proper screwdriver. The one included was not quite the right fit; that's why I stripped a screw. It would have been nice if some desoldering braid was included with the kit
My Problem
Exausted battery
My Fix
Well, almost exactly how explained in the guide. We fixed the battery cables instead of removing them.
My Advice
Be really careful with step 11 when reassembling!
My Problem
The Nano had stopped holding a charge.
My Fix
Fairly well given the very high difficulty of the repair. The end result was success.
My Advice
Desoldering the old battery was definitely the hardest part. Desoldering braid is a must, however it was impossible to remove every last bit of solder necessary to free the wires. I had success placing the shaft of a small screwdriver through the loops of battery wire on the backside of the board and using it to apply tension to the wire while heating the front side with the iron. With tension on the wire, it would pop free from the board once the solder pad was heated. I also needed to use a pin to ream out the holes in the board just a bit to get the new battery wires through. A hands-free magnifier was also very helpful in making the repair.
My Problem
Original battery only held charge for 10 minutes.
My Fix
Repair went ok for first time ipod repair. Taking it apart wasn't bad. A bit more of a challenge putting it back together.
My Advice
After repair, appeared that iPod was not working. Required reset after installing new battery. Flip Hold switch back and forth a couple times then press and hold Menu and Center button down at the same time for about 10 seconds.
My Problem
Three main problems for me :
1. The plastic pryer (green) didn't work well for me. It was finally crumpled. So I used a small flat-head screw-driver instead. Slightly scratched the nano but not significant.
2. I have no lead-removing strip. But a rather big vacuum one. Successfully cleaned up one hole. The other two holes, I melted the lead and quickly inserted the wire in. Not too difficult with proper clamping. What's quite nervous was I was afraid that I would've heated the hole for too long.
3. Sliding the inner parts back into the shell left some glue residue on the inside of display cover. I had to slide things back off, cleaned the inside of the display cover with alcohol, placed a long sheet of thin paper to shield the inside of the display cover, slid the whole things in, and pulled the thin paper out. Quite messed up in practice, but it's OK overall.
My Fix
Work perfectly. Can't be happier. The battery is charged faster and holds the energy longer. Seems even better than when I first had the nano.
My Advice
The delivery was much faster than the expected.
I'm an experienced electronic/digi
Related Questions
1 Answer 1 Score |
Not turning on after chargng, turns hot though. |
2 Answers 0 Score |
My 8 GB iPod model #A1199 |
