Click Image To Zoom
iPhone 4S Transparent Rear Glass Panel
$19.95 Was $29.95
You save $10.00!
Product code: IF115-004-1
Product Overview
For the best look at your iPhone 4S.
This part only fits the iPhone 4S. It looks great on both white and black iPhones. We have the equivalent product available for the iPhone 4 GSM/AT&T here.
  • Replaces opaque glass rear panel with transparent one to allow you to see your iPhone 4S's internals.
  • Complete with all necessary parts including camera lens, flash diffuser, and bezel.
  • The Pentalobe P2 screwdriver required for installation is available with replacement Phillips screws in our popular Liberation Kit.
  • You may also want to consider getting a nifty screen protector, so that your iPhone can play nice with your keys.
Note: If you have received your panel already and have an issue with blurry pictures or it looks like your lens is scratched, make sure you have removed the very thin protective film that is on the inside. It can be removed with your fingernail. Do not use something metal to take it off. If there is still some residue on the lens, a micro fiber cloth should take it right off.
Compatibility
Identify your iPhone
  • iPhone 4S
Product Details
  $19.95
Condition:
New
Warranty:
6 month warranty
Add to Cart »
50+ Available
Quantity:
Install Videos
Compatibility
iPhone 4S
16 GB
32 GB
64 GB
Stories
My Problem
My battery was running flatter faster and faster by the day and once even lasted from the remaining "2%" charge for 45+mins of consistent texting! Also saw the clear iPhone back on this site and thought why not!
My Fix
Repair was very easy with the small exception of the tiny battery "pressure contact" which was fiddly and took me some time to get back into place.
(I got the delivery on my way to school and couldn't wait to do it at home that night so I did the repair in the Tech room at school!)
My Advice
Was the easiest fix to do for something that had always been portrayed as difficult to do! As long as you do it in a clear space and ensure that you keep a tight hold on those tiny screws everything is easy.
My Problem
My iPhone fell on the ground and broke the rear glass panel.
My Fix
It was a little hard to fit the rear but with a little screwdriver I opened a little bit the plastic groove and it worked with some strength.
My Advice
It's worth!!
My Problem
The back glass shattered.
My Fix
Easy repair.
My Advice
After repair I found the same replacement glass later at 1/3 the price of Fix-it. Fix-it has great service and info but sometimes shopping around can save you quite a bit.
My Problem
After countless falls the rear glass cracked. Just couldn't take it any more.
My Fix
Not bad, but I'm concerned the panel wouldn't slide completely on. Maybe a millimeter off. It might just need extra force but it's not that noticeable and the screws tightened OK. Not going to bother until I'm ready to sell it.
My Advice
Not really.
My Problem
Wanted access to my phone and to get rid of the tacit advertisement for the iPhone.
My Fix
Super easy, but the nifty transparent rear glass broke the same day I installed it when I dropped it while showing it off. :-(
Back to advertising for Apple.
My Advice
At least use a bumper case.
My Problem
Now that my warranty had expired I wanted to swap out my back glass for the elegant transparent version. I had been wanting to do this for a while but I didn't want to void my warranty in case something happened to the phone.
My Fix
It wen great!! It took me about 5 minutes and completely changed how my phone looks now.
My Advice
Do it!!!
My Problem
The clear back glass is bada$$. Had to have it, and got rid of the pentalobe screws at the same time.
My Fix
Absolutely painless.
My Advice
DO IT!
My Problem
I dropped my iPhone and cracked the back glass. Replaced it with the transparent back because I was wanted my phone to be different from every other iPhone.
My Fix
Well I started off by ordering the wrong one. Lucky for me ifixit.com has the best customer service I've ever encountered! I would Definitely suggest this to anyone that asked. The actual installation took less then a minute. Anyone would be able to do this fix no problem
My Advice
Make sure you double check to make sure you are ordering the right part for the right phone.
My Problem
i'm from Singapore.. Credit card billing address & delivery address is different. They required me to fill up a form to prevent fraud.
My Fix
I replied via email, my billing address. They responded immediately & sent to my requested delivery address.
Received iphone 4S transparent rear glass panel with crack at the side. Took pictures and sent for advice. They sent a replacement immediately.
My Advice
Their service was excellent. Definitely will order from them again.
My Problem
My iPhone really dislikes being cooped up in the side pocket of my bag, so one day it decided to jump on out of there! It freefell a whole three feet to the wood floor, where the back coverglass sustained a moderate cracking injury. After the fall, I palpated some small shards of glass that were coming loose.
My Fix
Easy peasy! I used my friend's pentalobe screwdriver to remove the old panel and discard the cracked panel in our sharps container at the hospital where I work. I then replaced the rear glass panel with the new one and screwed that sucker in!
My Advice
Know how to remove the rear glass panel before taking the screws out. It took me a little while to get the old panel off. (it slides towards the top of the phone.)
